1997 Other Chevrolet Models 1997 suburban
1997 CHEVROLET
CORPSMAN
Transmission problem
1997 Other Chevrolet Models V8 Four Wheel Drive Automatic 198k miles
2 problems
1 the truck seems like its not shifting properly I have added fluid and I can see the level is good (while the truck is running after driving I checked again and nothing on the stick no visable leak completly dry underneath can't figure it out????
2 spedo tach not working as well as the PRND321 not visable (worked fine this morning) checked and replaced the fuse (#20 in the fuse cluster 10amp, says in the manual its associated with tach spedo auto transmission and PRND321) did not fix the problem
Jan 12, 2010 at 10:58 AM
HMAC300
  • 48,601 POSTS
both problems may be related to the speed sensor. That may be bad. A trans shop should be able to get a code for it and see if it's bad or not. they usually don't charg for this.
Jan 14, 2010 at 12:05 PM
