1995 Other Chevrolet Models CAMSHAFT SPROCKET GEAR REMOVAL
1995 CHEVROLET
263,198 MILES • 6 CYL • 2WD • AUTOMATIC
MTRDUDE
  • 51 POSTS
I'm working on a 1995 Chevy P30 stepvan with a 6.5L diesel. I replaced the water pump because it was leaking but then discovered the timing cover backside gasket was leaking also. I removed the pump, alternator and all other items to access the cover. I removed all the cover mounting bolts, including the oil pan bolts, as well as the vibration dampner. The camshaft sprocket has to be pulled out and away so the timing cover swings out. I removed the three bolts holding the sprocket in place but it won't pull out. You can move it in and out about 1/4" but it won't pull free. I need an answer as soon as possible so I can get the customer back his truck. You can call me at 843-532-5771 if you need additional information; I will be monitoring this site for your reply.
Oct 30, 2008 at 9:37 AM
JNOVACK
  • 723 POSTS
you will need to us a gear puller to get it off and then you can finish the job
Oct 30, 2008 at 1:50 PM
JAMES W.
  • 2,394 POSTS
Have you tried a couple of angle pry bars and "walking" the gear off? The only thing that holds the gear on are the 3 bolts.
Oct 30, 2008 at 1:55 PM
MTRDUDE
  • 51 POSTS
My main concern or question was if the gear was attached to the injector pump in back of the timing cover. I have pullers and have not tried to pry or pull it off yet because I didn't want to damage anything.
Oct 30, 2008 at 8:09 PM
JAMES W.
  • 2,394 POSTS
The injector pump runs off it's own gear on the camshaft. You shouldn't bother that.
Oct 31, 2008 at 11:34 AM
