1993 Other Chevrolet Models timing
1993 CHEVROLET
RAYOGLETREE
Engine Mechanical problem
1993 Other Chevrolet Models 6 cyl Two Wheel Drive Automatic 15k miles
if the motor is spitting back into the caborator could this be the timing
Feb 26, 2009 at 8:15 AM
BOGONE
  • 8 POSTS
Is it a constant pop, pop ,pop,pop, pop,............. Or isit a hesitation pop when you open the throttle? If it is a constant pop it is likely that it has jumped cam timing or burnt an valve. If it is a hesitation pop there is alot of things that would cause that.
[quote:7f92fd18d6="rayogletree"]Engine Mechanical problem
if the motor is spitting back into the caborator could this be the timing[/quote:7f92fd18d6]
Mar 19, 2009 at 7:00 AM
