1993 Other Chevrolet Models HEADLIGHTS WILL NOT WORK NEED TH
1993 CHEVROLET
TOYATA CAMRY
  • 6 POSTS
1993 Other Chevrolet Models V8
ITS A 1993 Chevy C1 series I was driving one night and both my headlights went off then came on then went off again then finally just stayed off the tail lights still work and the signal lights still work i dont know whats wrong with it and dont know how to fix it please help me it would help alot please my job is on the line
Aug 7, 2010 at 2:39 PM
KHLOW2008
  • 41,812 POSTS
Hi Toyata camry,
First of all you need to check if it is the bulbs that are faulty.
Is the dimmer working?
At the headlingt bulb, test for battery voltage with the light switch turned ON.
The Tan wire is for low beam and the Light Green is for the high beams.
If no voltage are available, check the beamer select switch. If battery voltage is available at the Yellow wire and none at either Tan ot Light Green wire the switch is bad.
If battery is not available at the Yellow wire, the Light switch is bad.
Aug 8, 2010 at 1:09 AM
