1992 Other Chevrolet Models timing marks
1992 CHEVROLET
WILDON59
1992 Other Chevrolet Models 6 cyl Two Wheel Drive 118000 miles
how to line up marks on cam and crank spockets?
Jul 1, 2009 at 12:12 AM
LOUT5369
  • 217 POSTS
On Chevy engines,The timing marks a Dot to dot,On the v6 & v8 when the marks are dot to dot ign is firing cyl # 6,When I say Dot To Dot I mean crankshaft mark at 12:00 camshaft at 6:00,Line distributor up so rotor points to #6 wire,and you'll be fine,with both marks at 12:00 cylinder #1 will be at TDC.good luck
Jul 27, 2009 at 11:23 PM
