I have performed a complete tune-up(plugs, wires, cap, and rotor), replaced fuel filter, fuel pump and sending unit.
Problem I am having is that it stalls out whenever hot or cold wet or dry. It will restart, I can sometimes feather gas to keep from stalling at times.
SPONSORED LINKS
Sunday, April 11th, 2010 AT 1:10 PM
HMAC300
MECHANIC
Go to the site here and look up tune up and the first picture is the throttle plate. Clean that with choke cleaner on both sides as well as the hole where the IAC is. Also clean around the TPS switch.
