1992 Other Chevrolet Models cranks over but wont start
1992 CHEVROLET
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
SWACKY
  • 6 POSTS
i changed the coils air flow sensor spark plug test tried starting fluid to see if it was fuel pump tried fuel pump relay nothing works can you help me
Mar 4, 2009 at 10:31 AM
IMPALASS
  • 3,112 POSTS
Hello
To better assist, please be specific on your vehicle model and be exact. Also your engine size in liter and the 8th digit of your VIN.
Mar 4, 2009 at 10:54 AM
SWACKY
  • 6 POSTS
engine is 3.8 vin digit is L lumina apv
Mar 6, 2009 at 9:11 AM
IMPALASS
  • 3,112 POSTS
Hello
Thanks for the info
First, do you know how to pull codes on the car?
Next, you turn the key and it continues to try to crank but never actually starts
When you say you tried the spark plug test: you did pull a plug wire off of the spark plug and insert something into the end of it and have someone try to start the car and have the metal object really close to a piece of metal on the engine and see if you are getting a good strong popping blue spark. So do you have a good blue spark on all plugs?
Please let me know what you find and if you are not sure how to pull the codes, let me know and I will tell you.
Mar 6, 2009 at 11:23 AM
SWACKY
  • 6 POSTS
yes i tried 1 spark plug wire it had good spark today i replaced the knock sensor still did not start code came up 43 from scanner coils changed air flow sensor fuel relay to many thinks it could be
Mar 7, 2009 at 10:48 AM
IMPALASS
  • 3,112 POSTS
Hello
Okay if you got good spark, then spray starting fluid in the throttle body and try to start again and let me know.
Mar 7, 2009 at 5:17 PM
SWACKY
  • 6 POSTS
that is the first thing i did. Fuel pump relay.Knock sensor coils changed them. Good spark
Mar 8, 2009 at 1:54 AM
IMPALASS
  • 3,112 POSTS
Hello swacky
Thanks for getting back with me
Yes, I understand that is the first thing you did but I need to know the results of when you do that..such as, the car sputtered, tried to start, engine just rotated and no difference
Those things are clues that I need
If you are getting a good spark from all the plugs not just one then we know the electrical as far as the spark is concerned is okay
If you spray starting fluid in it and it sputters it may be the fuel pump is not working. What is your fuel pressure?
If we are getting a good spark on everything, if we have good fuel pressure, then the next thing to check is the compression.do you have good compression on all the cylinders
But that is what we need to figure out
Also, are you sure about your model and engine size of car? I show the Lumina either has the 4cyl, 2.5L, or the 6 cylinder 3.1L VIN T, or 3.4L VIN X.
Now based off of the 8th digit of the VIN you gave me, L, you have a 3.1L..is this what you have?
Mar 8, 2009 at 6:37 AM
SWACKY
  • 6 POSTS
when i put starting fluid in it spins faster does not start. Sticker under the hood says engine is 3.8L.yesterday put in a knock sensor. cleared the codes now the sanner reads 12 no other codes come up
Mar 8, 2009 at 11:16 AM
IMPALASS
  • 3,112 POSTS
Hello
Hey thanks for the info
Wow .I will need to do some more checking
Anyway, while I am doing that spinning faster please do a compression check and let me know what each cylinder says
Good job by the way supplying info
Mar 8, 2009 at 12:03 PM
SWACKY
  • 6 POSTS
i tried starting fluid again the right way i sprayed it in hose to manifold the first time the second time i took off the breather cover and it tried to start so i guess it is fuel related could it be i got bad gas that night or the fuel filter or fuel pump need help thank you
Mar 9, 2009 at 3:28 PM
IMPALASS
  • 3,112 POSTS
Hello
Sorry so long to get back with you having some computer problems major ones, so please bear with me as I limp along here.
Okay great info ..you need to do a fuel pressure check 190K on the car it is probably the fuel pump. So check the pressure.
If it is bad I would also change the relay, filter and make sure you change the sock on the pump.
Mar 10, 2009 at 1:07 PM
