1992 Other Chevrolet Models converted engine
1992 CHEVROLET
136,000 MILES • V8 • 2WD • MANUAL
MICHAEL CRIST
My son-in-law has 1992 w/t1500 with a transplanted carb version V8. It has a fuel regulator in-line(2nd one) It will over flow the carburetor after running short while. I've put in new float and rebuild kit in carb. but it still has the over flow. If I diconnect the electric fuel pump and install a mechanical pump. Will iy have enough to pull fuel thru in tank pump? This thing is really a HILLBILLY dream! Or would it be better to return the engine back to a TBI system? All the wires for TBI seems to be still there. Third seniro, put a match to it?
Feb 1, 2009 at 5:08 AM
DOCFIXIT
  • 18,828 POSTS
First ckeck fuel pressure at carb must be no more than 7psi better at 5psi.
Feb 3, 2009 at 3:37 AM
