1991 Other Chevrolet Models S10 Blazer inconsistent starting
1991 CHEVROLET
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHAWN83
I am having problems getting my vehicle to start consistently. The engine cranks but doesn't turn over. I believe the issue precedes the coil. I replaced the coil but did not seem to be getting a spark from it. All related parts that are new include the fuel pump, filter, starter, distributor cap and rotor, coil and spark plug wires.
Sep 15, 2009 at 3:32 PM
PEAR69
  • 1,482 POSTS
You must test to see if you are getting spark and fuel. If no spark, then the next step is to have the ignition control module tested and/or replaced.
Sep 16, 2009 at 3:34 AM
