1991 Other Chevrolet Models 6.2 diesel malfunction
1991 CHEVROLET
200,000 MILES • V8 • 4WD • AUTOMATIC
KLSHIEL
  • 163 POSTS
I was driving my truck yesterday when all at once it felt and sounded like someone turned on the Jake brake. While it is a diesel my truck doesn't have an engine brake. I stopped the truck and shut it off. The belt had slipped off but I didn't see any other damage. I tried to re-start the truck and get it off the road, but the engine, which still sounded like it had an engine brake, died after 20 feet. I got the truck pushed into a parking lot and noticed fumes coming from the air cleaner. The intake was full of atomized fuel. The one explanation I can think of that fits is the timing was thrown off. I don't think this engine has a timing chain but a gear driven cam and push rods. Where should I start? Correction, my engine does have a timing chain. What is the correct procedure for base timing the valve train?
Jul 15, 2008 at 2:27 AM
KLSHIEL
  • 163 POSTS
You'll never believe it. I was tearing the front of the engine down to change the timing chain when I noticed movement in the crankshaft. Not rotation mind you but side to side up down movement. I didn't take the rest appart but the best answer I can find is that the crank is broken. Stay away from the 6.2
Jul 25, 2008 at 6:24 AM
