1988 Other Chevrolet Models has a miss on # 3 &8 cylinde
1988 CHEVROLET
158,000 MILES • V8 • 2WD • AUTOMATIC
GHOGUE
i have repleced the throttle body injection with a carboerator i have good compression and good spark that only leaves fuel do i need to change the intake also ,it has a miss on # 3 & # 8 cylinder
Nov 7, 2009 at 7:04 AM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Nov 7, 2009 at 8:31 AM
