1987 Other Chevrolet Models Heater gauge stays on cold
1987 CHEVROLET
17,800 MILES • 6 CYL • 2WD • MANUAL
JJDOG33
The vehicle is a chevy c-100 pickup truck. The problems are 1. The heat guage stays on cold no matter how long you drive it 2. The heat comes out when the engine warms a little, but the blower is not working. As far as the guage goes, wouldn't a bad thermostat typically cause the vehicle to heat up and the gauge to go hot instead of the opposite?
Nov 20, 2009 at 3:57 AM
HMAC300
  • 48,601 POSTS
try grounding out the wire going to the coolant switch and if the guage goes up it can be your coolant switch. You could also have a bad theromstate. They are easy enough to change an ddfairly cheap, try chaning that first.
Nov 25, 2009 at 7:38 AM
