Run a scan on your engine, cross A&B and count the light flashes to see if a sensor is going bad. Check your vacuum hose going to the map sensorif it's soft it could be not letting the map read to keep the car going. By dumping water remover n your fuel all you are doing is putting more alcohol in the fuel. You really don't need that clean your battery cables as well as you may not be getting enough juice to keep it running. Also go under tune up and it covers all ignition systems and check yours as it may be a reluctor or ecm in the dist causing the problem as well.
SPONSORED LINKS
Saturday, July 10th, 2010 AT 6:33 PM
