1986 Other Chevrolet Models battery
1986 CHEVROLET
WHITE_LIGHT79
Electrical problem
1986 Other Chevrolet Models 6 cyl Front Wheel Drive Automatic
what size battery was the the truck sent from the factory with?
What size battery would you recomend for the same truck that is being changed into a icecream truck?
Apr 25, 2010 at 11:49 PM
HMAC300
  • 48,601 POSTS
if you are going to run anything bby 12 volt and if you have a/c or any power stuff put the largest size battery you can fit. That means by cranking amps.
Apr 26, 2010 at 10:59 AM
