1985 Other Chevrolet Models NO DASH LIGHTS
1985 CHEVROLET
175,000 MILES • V8 • 2WD • MANUAL
DAVID NOEL
HELLO GUYS, I HAVE JUST RECENTLY BOUGHT THIS 1985 CHEVY 2500 AND I HAVE NO DASH LIGHTS. WHEN I TURN ON THE LIGHTS THE HAZARD LIGHTS ON DASH ARE ON SOLID WITH NO DASH LIGHTS. ALSO THE WIPERS WILL NOT TURN ON. THE WIPERS ARE CONTROLLED ON STEERING COLUMN. ANY SUGGESTIONS WOULD BE VERY HELPFUL.
Feb 23, 2008 at 9:49 PM
MASTERTECHTIM
  • 4,750 POSTS
you have at least 3 seperate problems. first of all check the fuse for the dash lights, its a 5 amp. do your running lights work? check the tail light fuse. if all ok check for power at the brown wire at the back of the headlight switch, if no good then replace the headlight switch. also the gray wire feeds the dash lights. your wipers. check for power when turned on, at the motor, if you have power then check to see if the motor is grounded.. the ground for the motor is through the motor itself. a lot of times the motor loses ground and you can add a ground wire to the body of the wiper motor
Feb 23, 2008 at 11:37 PM
