1984 Other Chevrolet Models gears
1984 CHEVROLET
WESLEY14
Drive Train Axles Bearings problem
1984 Other Chevrolet Models V8 Four Wheel Drive Manual
is 3.73 gears the right size for 31-10.5-15 tires
Mar 14, 2010 at 5:01 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
it should be ok but if you can get someone to figure this out mathematically to figure out the real ratio. You can only go up to a 4:10 ratio unless you go to speciallty gears for that rear end. It really depends on what kind of power you have .
Mar 15, 2010 at 7:43 PM
