1978 chevy c 10 pickup truck
1978 CHEVROLET
PBFED
I have a 1978 c 10 chevy pickup I'm haveing alot of blue smoke coming from the tail pipe I thought it was burning oil but I'm not sure it smells like your riding behind a bus it doesn't smell like oil...but if it is will replaceing the valve seals cure this problem....
Oct 23, 2007 at 10:39 AM
MERLIN2021
  • 17,250 POSTS
What color? black blue or white? Black= too rich fuel mixture, or choke partially closed, blue= burning oil, white= may be burning antifreeze! Head gasket?
If it's blue, and it needs valve guide seals, problem will be more pronouched on take off...
Oct 23, 2007 at 10:43 AM
The blue smoke is an indication of oil being burn in the combustion chamber. Probably due for an engine overhaul.
Do an engine compression/leadown test to find out where you stand at for what is really need to be rebuild.
Oct 23, 2007 at 11:01 AM
