1975 Other Chevrolet Models
1975 CHEVROLET
186,000 MILES • V8 • 2WD • AUTOMATIC
RYANRIOT
I have a 1975 chevy pickup. and my sister was driving it the engine was running really hot and eventually it died. its not starting. it wont even turn over.
Jul 25, 2009 at 5:28 PM
  • 75,988 POSTS
Do below and comeback with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jul 25, 2009 at 7:08 PM
RYANRIOT
[quote:73459b2b0f="rasmataz"]Do below and comeback with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it[/quote:73459b2b0f]
well how do you ground it?
Jul 26, 2009 at 2:18 AM
  • 75,988 POSTS
Ground it to any good ground point about 1/8 in away from the ground. Use the valve cover.
Jul 26, 2009 at 7:13 AM
LOUT5369
  • 217 POSTS
It won't spin over by using the starter? Put a socket with a breaker bar on the crankshaft bolt and try to turn the engine manually,if it still won't move,remove all the sparkplugs,and try to spin the motor with the breakerbar again,sounds like the headgasket blew and you have a cylinder filled with coolant.Let me know how you make out.Lou
Jul 27, 2009 at 11:29 PM
  • 75,988 POSTS
If the word was overheated I would have given you how to check for hydrolock, lout5369 has given you a good advice follow it and get back
Jul 28, 2009 at 6:00 AM
