I turn the key and it sounds like all the starter does is just wine. Help.
May 26, 2009 at 7:42 AM
JDL
✓Experienced Mechanic
Underneath, there may be a flywheel cover, if you remove the cover, you may be able to see if the starter is kicking out the pinion gear, if it isn't, you may need a new starter/solenoid assembly.
