1972 Other Chevrolet Models over charging
1972 CHEVROLET
MATTP1972
Electrical problem
1972 Other Chevrolet Models V8 Two Wheel Drive Manual
my alt is charging to =17 amps changed the external reg.
changed the alt still over charging
looked over the wires under the dash and changed 1
from the key to the firewall
if i do not hook this wire up it will not charge
if i do it charges and the amps keep going up
Nov 6, 2009 at 9:51 AM
HMAC300
  • 48,601 POSTS
17 amps shouldn't be anything to worry about. Your alternator is probably around 35 -40 amp max. Especially if you have your headlights or a/c on. However if it is charging at 17 volts then it is overcharging and check for a bad battery or a sulfated battery.
Nov 8, 2009 at 2:39 AM
