1970 Other Chevrolet Models
1970 CHEVROLET
3,000 MILES • V8 • 2WD • AUTOMATIC
GQ
I have a crate 350 motor from Chevy. Is it easy to change valve cover gaskets? If so could you let me know how? Also, what should I set the gap at on the spark plugs?
Thanks
Nov 1, 2008 at 1:09 PM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Plug gap will be about .35, Remove the small bolts holding the valve covers on, scrape old gasket off, install new gasket pushing the tabs into place and reinstal, DO NOT over tighten, snug will do fine!
Nov 1, 2008 at 1:15 PM
