Engine Mechanical problem
1968 Other Chevrolet Models Two Wheel Drive Automatic
No fire! 350 small block in a 1968 Chevy C10 pick up. It has a HEI distributor & all components of the distrub are brand new & I had them all checked to be sure I didn't blow them somehow. There is defiantly fire (current) going into the distrib I checked it with a test light. There are new plugs & wires as well. The rotor turns while cranking and the metal piece under it is making contact with the nipple on the bottom of the distrib cap. I have the block grounded to the frame. I have done this next part two ways #1 piston up with rotor pointing to #1 plug and at 180 out with #1 piston up and rotor pointing to # 6. I also switched all the plugs around the distrib, for the 180 out method. I have hand turned the engine to TDC at 0 and 4 and in between. I should say, I just did a complete overhaul of the engine BUT! I must add, that prior to the overhaul, just all of the sudden I had NO fire! So no fire before I tore into it & no fire after I tore into it. I lined the dots up on crank. Help
Apr 20, 2010 at 2:34 PM
