1966 Other Chevrolet Models power
1966 CHEVROLET
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
CORAIROWNER
My corvair hadn't been started in 6 years and now it has no power.
Oct 22, 2008 at 11:04 AM
DOCFIXIT
  • 18,828 POSTS
Have you tuned it replaced fuel filter and drained old fuel added fresh? Changed oil ? Carbs may need rebuilt if gas was left in fuel bowl.
Oct 23, 2008 at 6:23 AM
CORAIROWNER
[quote:a5f35df7e6="Docfixit"]Have you tuned it replaced fuel filter and drained old fuel added fresh? Changed oil ? Carbs may need rebuilt if gas was left in fuel bowl.[/quote:a5f35df7e6]
yes
Oct 25, 2008 at 8:11 PM
DOCFIXIT
  • 18,828 POSTS
Check spark pull wire hold next to block should see blue/white spark 1/2 in. nice crack. If not coil weak
Also check to see if centrifugal advance is working. Weights may have siezed.
Oct 26, 2008 at 4:32 AM
