OVERHEATING
60,000 MILES • 4 CYL • AWD • AUTOMATIC
REFOUP
my car is always overheating and now it's leaking from under the engine. all the coolant you put it runs out from under the engine.....what is wrong with it?
Mar 31, 2010 at 3:04 PM
LEGITIMATE007
  • 5,121 POSTS
I suspect a lower radiator hose is bad, does it seem to be coming from the front or back of the engine?
This guide can help us fix the problem.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Mar 31, 2010 at 4:02 PM
REFOUP
thanks for the reply leg....007.....the leak seems to be coming from the back underneath the engine....
Apr 1, 2010 at 10:47 AM
LEGITIMATE007
  • 5,121 POSTS
it could be a freeze plug, but I doubt it, I think it is one of three things, a broken heater core, and the fluid is leaking through the condensation drain in the firewall(not likely) or the heater hose going into the firewall, water pump, or the lower radiator hose.(I guess that is four,but one is not likely)
This guide will help you find the leak
https://www.2carpros.com/articles/car-is-leaking-coolant
keep me posted
Apr 2, 2010 at 2:03 AM
REFOUP
thank you very much for the update. I am not really good with car technicality, and someone is looking at it. It's been three days and there is no update from him yet. And I will keep you posted.
Apr 4, 2010 at 1:05 PM
LEGITIMATE007
  • 5,121 POSTS
your very welcome, and please keep me posted as to what happens, we will always be here if you need us
Apr 5, 2010 at 1:33 AM
DENNIS MARTIN
my 2007 chevy optra was overheating
1- i found out my welch plugs (three plug on front and three on rear of engine block) were leaking - had my mechanic replaced with the copper types.
1- i unplugged all my radiator fans started the engine.....then shut off plug them on again and started.....fans running like normal cars these days
usually those fans wouldnt come on until the AC is turned on now i can hear them coming on in traffic especially the high seed mode.
periodically check your fans....especially after rain or water
no problen since
Jul 14, 2011 at 3:42 PM
LEGITIMATE007
  • 5,121 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Jul 15, 2011 at 6:29 AM
