2004 Chevy Optra when stopped at a light the car idols funn
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTTY23
seem since weather started getting cooler every time i am waiting for light to change car idols funny and sometimes it stalls, what is the cause?
Nov 9, 2009 at 12:00 AM
  • 110,248 POSTS
Has the check engine light come on? There are several things that can cause this. Without an trouble code, it becomes a guessing game. THat is why I asked about the light.
Also, have you checked to see if there are any loose, damaged, or disonnected vacuum lines?
Finally, my gut feeling is the problem is coming from the ambient temp sensor. However, as I mentioned, that is a guess without the light coming on. Does the problem happen regardless of engine temp?
Nov 12, 2009 at 12:11 PM
SCOTTY23
there is no engine light that goes on and it seems to do this even if the car is cold or warm.
Nov 15, 2009 at 4:39 PM
