2004 Chevy Optra Coolant
2004 CHEVROLET OPTRA
35,000 MILES • 4 CYL • FWD • AUTOMATIC
BONNEAU
Hi
I am loosing coolant every time I drive but see no leaking anywhere...what could it be and will it be costly to fix.....oh I did have my car over heat twice...lost coolant due to a hose coming off and again when the thermostat housing cracked...made of plastic had it replaced with a metal one.
thanks...have a nice day.
Sep 16, 2010 at 9:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Sorry for the slow response
Normally when the coolant is leaking slowly but there is no visible signs of leakage anywhere that is a good sign of a cracked head gasket. The coolant could be seeping past the cylinder head gasket and being burnt in the engine and blown out the exhaust either as white smoke or if it's a very small leak you may not even notice smoke at all. You will want to have a compression test done on the cylinders to check for a cracked gasket.
Sep 20, 2010 at 8:58 AM
