1988 Chevy Nova Idling
56,000 MILES • 4 CYL • FWD • AUTOMATIC
MUSTANG10522
My 1998 chevy nova car idles just a bit high in park or nuetral and you pretty much don't feel anything. As soon as you drop it in drive or reverse it vibrates or shake, not much, but I know this can be fixed. I don'r expect perfection, but. Can you help? What can I do?
thanks
mike
Oct 13, 2008 at 2:38 AM
MMPRINCE4000
  • 8,548 POSTS
Determine the cause of the high idle, usually a vacuum leak, or stuck Idle Air Control valve.
The shaking is more that likely a bad motor mount, collapsed or simply worn out.
Oct 24, 2008 at 11:44 PM
