1988 Chevy Nova car won't start
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVEC1982
I have this "mystery" problem with my 88 nova. The problem is that after i drive my car to where i need to go, it wo't start when i try to turn it on again. The car won't turn over, i don't hear any clicking noises wheni turn the key, i have full lights, and they DON'T dim, so it's not the battery, you CAN jump it as long as it's car to car and not car to jump box, i just recently put a new starter in and that didn't really solve anything, anyadvice or if you have a solution i would be very grateful
-David Capano
Aug 12, 2010 at 5:41 AM
  • 75,988 POSTS
Check and test the neutral start switch and ignition switch
Aug 12, 2010 at 10:09 AM
BOBALOU
David, I am experiencing the same exact problems. Your description of the "mystery" problem is the same as mine in my 1987 Chevy Nova.
I have replaced the ignition switch. I have also checked the neutral switch. Neither seems to be the cause of the problem.
Aug 12, 2010 at 3:18 PM
  • 75,988 POSTS
TO: bobalou
Try this have helper hold key in cranking position and check for power at the neutral switch black and white wire do you have it?
Aug 12, 2010 at 3:37 PM
