1978 Chevy Nova runs for a while, then stalls
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
KPATRICK
The car starts up fine and will run as long as you do not slow down to turn or stop after it has warmed up. When you do this the car struggle to run, seems to have no power and will die after trying to run. If you let it set for a couple of hour it will run again for awhile. Also, if you take the air cleaner cover off and leave it off or leave it cracked open it will run fine. I have replaced the air filter and this does not help.
Oct 27, 2010 at 3:02 AM
  • 75,988 POSTS
Check the thermostatic air cleaner, also the heat control valve and also clean out the EGR valve and see what happens
Oct 27, 2010 at 3:14 AM
