Look for spark-disconnect a sparkplug wire and ground it to the engine while cranking it over-are you getting spark? If not could be the coil/ignition control module, pick-up coil in the distributor or power input to the coil from ignition switch.
SPONSORED LINKS
Saturday, December 15th, 2007 AT 11:45 AM
