1974 Chevy Nova ignition
58,000 MILES • V8 • 2WD • AUTOMATIC
FIREMAN_TURNER
my engine when it gets hot won't turn off, iwas wandering if it is the ignition how do i replace the switch?
Aug 16, 2008 at 9:48 AM
  • 75,988 POSTS
You probably have a run-on which is also called dieseling-Drop your idle speed and make sure the fast idle cam is not binding if it continues we'll use a different approach. Good Luck
Aug 27, 2008 at 8:57 AM
