1973 Chevy Nova valve adjustment
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEVIN J RYERSON
ok so i have pulled the head off and replaced the head gasket putt the head back on torqued the head back on. so now what?
May 9, 2010 at 7:44 AM
HMAC300
  • 48,601 POSTS
bring each cylinder up to TDC the adjust your valve lash to zero. Once you have that , and that means the push rods should still be able to slightly spin, adjust 3/4 to 1 turn down. Of course if they are solid lifter then you need to adjust it to the specs of the cam that is in the engine.
Jun 10, 2010 at 11:09 AM
