1973 Chevy Nova ignition coil
170,000 MILES • V8 • 2WD • AUTOMATIC
BILLMEMP
I have rebuilt the engine and an having problems with the wiring. I hooked up to brand new coil. 12 volts to (+) side of coil and distributor wire to (-) side of the coil. I'm getting 12 volts on both sides of the coil with ignition key on. However not getting any spark from secondary wire. what could be the problem. I have a wiring diagram for this year nova and it shows that the hot primary wire on (+), and the distributor and the starter wire going to the (-) side
Mar 14, 2008 at 12:11 PM
BILLMEMP
[quote:e0478148cb="billmemp"]Electrical problem
1973 Chevy Nova V8 Two Wheel Drive Automatic 170000 miles
I have rebuilt the engine and an having problems with the wiring. I hooked up to brand new coil. 12 volts to (+) side of coil and distributor wire to (-) side of the coil. I'm getting 12 volts on both sides of the coil with ignition key on. However not getting any spark from secondary wire. what could be the problem. I have a wiring diagram for this year nova and it shows that the hot primary wire on (+), and the distributor and the starter wire going to the (-) side[/quote:e0478148cb]
Mar 16, 2008 at 6:27 AM
