1972 Chevy Nova IGNITION SWITCH REMOVAL
KEVIN CARPENTER
1972 Chevy Nova
I AM HAVING TROUBLE REMOVING THE IGNITION SWITCH. CAN YOU GIVE ME ANY IDEAS? THANKS, KEVIN
May 1, 2009 at 2:00 PM
MIKE H R
  • 3,094 POSTS
Disconnect battery, put key in ignition and turn counter clockwise to accessories. Use a paper clip and stick it in the small hole on the key cylinder and push it in. While pushing it in turn the key a little more counterclockwise. {about a 1/8 of a turn. Then the key cylinder will come out. remove the housing around the steering column, remove the screw holding the ignition switch and then remove.
Oct 19, 2010 at 3:38 AM
