Not getting any fire to the spark plugs, any suggestions?
Nov 13, 2007 at 5:23 AM
✓Experienced Mechanic
Pull the coil wire at the distributor-ground it to the engine and crank engine over-do you have spark. No spark check for power at the coils power input terminal power there.
Could be the ignition contact point/s or the ICM if its an HEI
Nov 13, 2007 at 5:47 AM
ED ARMES
70 Nova has conventional ignition system with points and condensor. Major reasons for no fire are: coroded connections in distributor, bad points or condensor, poor adjustment on points ( .017 to .019 ), bushings bad in distributor that do not open points properley ( common ).
Feb 29, 2008 at 1:12 PM
Check the coil's primary and secondary windings. Then adjust the contact points as stated then use a dwell meter and adjust the dwell angle.
