1969 Chevy Nova leaking compression
350NOVA
Engine Mechanical problem
1969 Chevy Nova V8 Two Wheel Drive Automatic
how would i fix a head that is leaking compression from the number 4 spark plug hole on my small block 350?
Apr 27, 2010 at 1:56 PM
  • 31,937 POSTS
Hi there,
if you have a compression leak at the spark plug hole, i would be thinking that there is a crack you will need to get a crack test done to determine if this is so.
mark (mhpautos)
Apr 27, 2010 at 7:08 PM
