1968 Chevy Nova ignition switch
RAPTRR
Electrical problem
1968 Chevy Nova 4 cyl Two Wheel Drive Automatic
Need help on how to change an ignition switch
Jul 25, 2008 at 2:06 AM
HMAC300
  • 48,601 POSTS
if you are replacing the switch you need to take out the ignition tumbler. You need the keys for it and a paper clip. stick the key in and the paper clip in the small hole in the tumbler. turn to accessorie and push the paperclip in the hole and the tumbler should come out. Then the switch should be able to be unbolted from teh dash. If it's on the column then you need to drop the column down and remove the two bolts that hold the switch in at the bottom of the column.,
Sep 15, 2009 at 1:04 PM
