1966 Chevy Nova engine codes
22,000 MILES • V8 • 2WD • MANUAL
MASTERTECH25
my engine block reads 3908952,the last 4 digits are barely readable,theres no such # in my books,could this be a 3903352 block ?
Jun 10, 2010 at 11:36 AM
  • 75,988 POSTS
Go to www.batauto.com they have the no.s there for the small and big blocks
Jun 10, 2010 at 12:07 PM
HMAC300
  • 48,601 POSTS
that is the part number for teh engine block. If you look on the pad in front of the right cylinder head there will be numbers there. It will be behind the alternator. If you send me the code numbers via private message i can tell you what the engine was originally used for. it will have a letter like fa or v or k or t, then numbers then 3 letters like cab. send that to me via private message then i can get back with you fairly quick.....
Jun 15, 2010 at 12:12 PM
