Monday, March 9th, 2009 AT 5:22 PM
I have a 65 chevy II nova. When the engine gets to temp it will run very rich and stall out. It will not start on its own, after that. If I pour gas into the carb it will start long enough to burn off the gas I poured into the carb, and then dies. After a few times it will usually stay running long enough to get me home. When I pour the gas into the carb the gas actually boils in the carb. I dont believe the carb should be that hot and I think the reason it works after a bit is the gas cools the carb enough to run. What would cause the carb to get that hot and how can I fix it. Any other ideas would be appreciated. The entire fuel system is new or rebuilt from the gas tank all the way to the carb.
