monte carlo lost horsepower,barely makes it uphill
SNOWWHITE111
I have a 2002 Monte Carlo LS,102000 miles, has hardly any horsepower and going uphill is quite a strain. It usually wont get over 40 mph and if I give it more gas rpm's just go higher,but no speed. Getting up to 40 mph takes alot of effort.Computer code said it was EGR valve...had it replaced and still no better. Boyfriend thinks it might be catalytic converter. I don't smell anything at all...like fuel. It doesn't chug like it's not getting fuel.I had it completely floored one day and the rpm never went higher than 2500 and the speed never increased. When the car is just idling...it sounds great.
Thank you in advance for a reply!!
May 9, 2007 at 5:09 AM
2CARPRO JACK
  • 11,533 POSTS
Your boyfriend might be onto something. Loosen the exhaust bolts before the cat and see if it runs better, little loud but an easy way to diagnose the problem
May 9, 2007 at 5:43 AM
SNOWWHITE111
Hi again. Would he just be loosening the bolts or taking off the entire converter? Thanks!
May 9, 2007 at 5:48 AM
SERVICE WRITER
  • 9,123 POSTS
I think Jack means to remove the bolts, support the exhaust system (with wire), so that the exhaust flows freely without going through the converter.
May 9, 2007 at 12:05 PM
SNOWWHITE111
Hey thanks so much for your replies! I told my boyfriend about loosening the bolts,but instead we just took it down to Apex and got a new cat put on. Runs superb again!! I am soooo happy my baby car is all better! I had to drive about 13 miles or so to the shop and didn't think I was going to make it. Top speed I could go was about 32 in a 45 zone....LOL. So thanks again for the reply!
May 9, 2007 at 3:50 PM
