low tire pressure light
CHEVROLET MONTE CARLO
JLANGNESE
i just had 4 brand new tires put on and the light stays on , what could be causing this
Apr 5, 2007 at 8:03 AM
JOECLARK1906
[quote:fe78bc2c68="jlangnese"]i just had 4 brand new tires put on and the light stays on , what could be causing this[/quote:fe78bc2c68]
the low tire pressure light needs to be reset with your factory stereo. power the car radio off, turn the key to off, turn back to acc, hold down on the tune button on the radio, it should display settings, use the seek buttons and scroll to tire monitor, press next, then reset using the tune button, turn key back to off and then on, light will cut off. let me know if this works.
Aug 3, 2007 at 6:39 AM
KKIDD4
  • 5 POSTS
[quote:295ee7136b="JoeClark1906"][quote:295ee7136b="jlangnese"]i just had 4 brand new tires put on and the light stays on , what could be causing this[/quote:295ee7136b]
the low tire pressure light needs to be reset with your factory stereo. power the car radio off, turn the key to off, turn back to acc, hold down on the tune button on the radio, it should display settings, use the seek buttons and scroll to tire monitor, press next, then reset using the tune button, turn key back to off and then on, light will cut off. let me know if this works.[/quote:295ee7136b]
if u dont have factory stereo in your car anymore you can reset the light by turning key to accessory and pulling headlight knob out to parking light position and off position 3 times turn key off and it should be reset let us know k? thanks
Aug 3, 2007 at 7:27 AM
