Computer Problem?
HANNAHEDWARDS23
I have a 1996 Monte Carlo 3.1 with about 150,000 miles. When we got it, it still ran we thought the only problem was the intake gasket and needed a new battery. We replaced all gaskets an oil change and antifreeze change of course. All done and put back together now it will turn over but not start. We hooked it up to a diagnostic computer and the car computer is telling the car it is running when it really isn't. If you could please help me figure out what it could be. Thanks Hannah
Apr 18, 2007 at 3:11 PM
SERVICE WRITER
  • 9,123 POSTS
you need to go back to basic troubleshooting. Recheck that the wires are in the right order, and everything has been connected up properly.
If everything is good, start by checking for fuel and spark being present. IF so, compression test cylinders.
Apr 18, 2007 at 3:15 PM
HANNAHEDWARDS23
We have check all of that and everything is fine but still it still cracks but won't start. The diagnostics computer is still saying the the car computer is saying the car is running.
Apr 19, 2007 at 2:53 AM
