Car would not start
MARIOV
2003 Monte Carlo Ls 3.4 ingine 65,000 mileage
All gages work when turn the swich on ,Radio dont work and ingine would not turn over. please help!
Apr 19, 2007 at 9:52 AM
  • 75,988 POSTS
[quote:574e39268e="mariov"]2003 Monte Carlo Ls 3.4 ingine 65,000 mileage
All gages work when turn the swich on ,Radio dont work and ingine would not turn over. please help![/quote:574e39268e]
Is this the issue: cranks over and refuses to start or it will not crank at all
We need 4-ingredients that is cranking speed,compression.fuel and ignition to get a No start to jump back up and go.
Cranking speed: Battery must be in good condition to turn engine over atleast a min. of 200rpm.
Could be a bad connections at both ends of the Pos. and Neg cables, Ignition switch,NSS,starter relay and starter get these area check and comeback we still got a long way to go.
Apr 20, 2007 at 12:20 AM
MARIOV
my battery went dead i recharge it however i try to start the engine ,turn key and i get nothing could it be that the theftlock audio system shut down if so how can i reset it
Apr 20, 2007 at 5:32 PM
  • 75,988 POSTS
[quote:7a0c17ab3d="mariov"]my battery went dead i recharge it however i try to start the engine ,turn key and i get nothing could it be that the theftlock audio system shut down if so how can i reset it[/quote:7a0c17ab3d]
Your best bet is to call the dealer-
Apr 20, 2007 at 6:04 PM
