2007 Chevy Monte Carlo help
ZYNISA
Tires and Wheels problem
2007 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic
Can I put tires from a 2002 chevy blazer onto a 2007 chevy monte carlo?
Aug 9, 2008 at 2:05 PM
SERVICE WRITER
  • 9,123 POSTS
Tires onto the other rims?
What size are the two different tires?
Aug 9, 2008 at 5:02 PM
MY ZER
You can use the tires if they are the same diameter as the tires on your monte carlo.If you put different diameter tires on your ABS sensors will not work properly.
Aug 13, 2008 at 5:49 AM
SERVICE WRITER
  • 9,123 POSTS
If they are wider though, they will probably rub on turns. Gotta keep the middle number of the size in mind as well.
Aug 13, 2008 at 1:11 PM
