2007 Chevy Monte Carlo Engine Light
45,500 MILES • V8 • FWD • AUTOMATIC
SCOODY62
My wife was pumping gas in the car while it was running, ten minutes later she said the engine light came. Now every time we try to pump gas in the car, the pump keep shuting off as if the gas tank is full when it's not. So can you tell me what might be the problem?
May 22, 2009 at 9:57 PM
2CARPRO JACK
  • 11,533 POSTS
Gross evap leak from having the gas cap off while the car is running.The evaporative systems are completely closed now, if there is any place for fuel vapor to get out (leak) it will set the light
May 23, 2009 at 1:35 AM
SCOODY62
[quote:88419100c8="2CarPro Jack"]Gross evap leak from having the gas cap off while the car is running.The evaporative systems are completely closed now, if there is any place for fuel vapor to get out (leak) it will set the light[/quote:88419100c8]
ok, so how do I turn the light off or correct the problrm?
May 25, 2009 at 9:48 AM
2CARPRO JACK
  • 11,533 POSTS
Be sure the gas cap is on tight and then have the codes read, cleared.Ask for the code number just to be sure
May 26, 2009 at 12:19 AM
SCOODY62
[quote:d01e816b38="2CarPro Jack"]Be sure the gas cap is on tight and then have the codes read, cleared.Ask for the code number just to be sure[/quote:d01e816b38]
Ok, thank you.
May 26, 2009 at 6:03 PM
2CARPRO JACK
  • 11,533 POSTS
You're welcome , and remember always shut your car off to fuel it up
May 27, 2009 at 12:37 AM
