2007 Chevy Monte Carlo
2007 CHEVROLET MONTE CARLO
69,000 MILES • V8 • FWD • AUTOMATIC
SCOODY62
Can you do a rear wheel aligment on this car?
Jan 8, 2010 at 1:47 AM
MATHIASO
  • 1,209 POSTS
Hello _
Yes you can.
If toe wear is accompanied by steering pull or off-center steering, rear wheel toe alignment or axle alignment may be out of specifications.
Wheel alignment refers to the geometrical relationship of the wheels to the vehicle itself, to each other and to the road. Ideally, all four wheels should be aimed straight ahead, parallel to each other, perpendicular to the road and perpendicular to their respective axles. This will produce the least amount of rolling resistance, the least amount of friction, the least amount of tire wear and the greatest traction.
In all vehicles, the rear alignment must be correct before any corrections are made to the front.
Jan 8, 2010 at 10:40 AM
