2006 Chevy Monte Carlo IT RUNING ON 3 CYL
78,324 MILES • V8 • 2WD • AUTOMATIC
WORK.HARVEY
THE CAR IS NOT GETING INJECTOR PUSE ON ALL 8 CYL JUST 3 CYL GETING PUSE I CHECK THE WIRE FROM THE ECM BUT ON PUSE IS COMEING OUT BUT 3 OF THEM CAN YOU HELP ME I NEED THE CAR TO GET TO WORK I WENT FROM SHOP TO SHOP SENDING MONEY AN GETING TOW BACK HOME
Sep 17, 2010 at 4:05 PM
ERNEST CLARK
  • 1,730 POSTS
It's possible that your computer is in what they call "Limp home mode". you'll need to have the computer scanned and reset if this is the case.
If not, and you're sure the wiring harness and connectors are good, then your computer is bad.
Sep 17, 2010 at 11:28 PM
WORK.HARVEY
[quote:eae1d41ebe="Ernest Clark"]It's possible that your computer is in what they call "Limp home mode". you'll need to have the computer scanned and reset if this is the case.
If not, and you're sure the wiring harness and connectors are good, then your computer is bad.[/quote:eae1d41ebe]
Sep 18, 2010 at 10:22 AM
