2006 Chevy Monte Carlo gas cap
65,000 MILES • 6 CYL • FWD • AUTOMATIC
VALSEVEN
keep receiving a tighten gas cap signal on dash along with a steady check engine light. Bought a new gas cap three times, each time except this last time the check engine light went away. Now it has been on for over a week and keeps saying tighten gas cap even with new cap installed again. Have even tried changing fuel type from regular to mid-grade and still have the same problem
Aug 25, 2009 at 2:13 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Need to find out what code is that is causing light. Go to an Auto Zone have codes read then post will advise.
Thanks for donate
Aug 25, 2009 at 2:27 AM
VALSEVEN
upon calling onstar to do a diagnostics they repllied it was an evap failure. Do you still need the codes. If you need to call, call and ask for my husband, Ricky he's the one inquiring. 414-931-0654 or 414-544-2841
Aug 25, 2009 at 2:37 AM
DOCFIXIT
  • 18,828 POSTS
Yes need code number there are about 75 codes dealing with Evap failures. need in P0xxx format
Aug 25, 2009 at 2:50 AM
VALSEVEN
the code is po455
Aug 25, 2009 at 4:01 AM
DOCFIXIT
  • 18,828 POSTS
That is for large Evap leak. testing requires some special equipment. Other than visual inspection of system, see diagram, will likely be hose off evap canister . or line kinked or off tank. This may need a trip to shop but first open hood lok around .
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_102.jpg
Aug 25, 2009 at 4:23 AM
