2006 Chevy Monte Carlo Brake Pedal vibrates
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
28GHOST
I have a brake pedal that vibrates both when I am driving and when I am applying the brake. Typically this occurs between 40 and 70 MPH. I took it to the DEALER and they havent been able to stop it - but they have replaced bearings in the front and the front axel. I have, on my own, replaced all of the tires and had them balanced, plus had a front brake job done. I figure it cant be the rear brakes causing pedal vibration ? While driving ? Suggestions, all i can think to do is go to another dealer
Sep 20, 2008 at 1:31 PM
  • 75,988 POSTS
Sounds like you have a warped rotor/s have them miked out
Sep 20, 2008 at 5:23 PM
