2006 Chevy Monte Carlo Air Conditioning System Knocking
34,800 MILES • 6 CYL • 2WD • AUTOMATIC
CHARTS79
When I start the car, while on "Outside Air" setting, the air conditioning system knocks for a minute and stops. If I turn the car off and again, it doesn't make a knocking sound until the next time the car is shut off and started again. If I switch to the "Recirculation" setting, then it doesn't make a knocking sound. It sounds like it's coming from the top of the passenger side dashboard. Any ideas?
Aug 14, 2010 at 8:37 PM
MDIAZ1217
There is an electronic part that controls the air condition outside and inside circulation. It is behind the Glove Compartment. To change it , remove the Glove compartment, and you will see it on your right hand side. Just a few screws and an electrical plug and that is.
As soon as you change it, the knocks will end. That part is known as an actuator with the following numbers:
ACD# 15-73517
GM #15844096
Sep 11, 2010 at 9:22 AM
